I want to keep the furniture quotas fixed on the drawing so that it is clearly understood how to place the furniture in the room.
Using CAD Software (e.g., AutoCAD, SketchUp) Look for a properties or dimensions panel where the current size of the object is displayed. Adjust Dimensions: Manually enter the desired dimensions for width, height, and depth. These fields typically allow for direct input of numerical values. Scale Tool: Use the scale tool if the software supports it. Select the object and then use the scale tool to adjust it to the desired dimensions proportionately. Check Constraints: Ensure there are no constraints or groupings that might prevent modifications. Unlock or ungroup objects if necessary.
