Does anyone know how to create custom murals/paintings with my own image? I tried uploading the image but it only works as a texture/material.
Use a very high quality jpg, load as 2D model> texture. When editing, category> texture library> scroll down and choose 'custom map', where it asks for the size, put in the measurements of the jpg: 1920x1080, 3500x2800...Do not worry about cm/mm/in/ft., click OK. When applying the texture apply as 'tile flooring', this will allow you to scale to fit the wall or a section of the wall. Same method can be used with a HS model picture frame-as long as the model will allow you to change the picture. Examples on left are HS wall, on the right is custom modeling wall.
