You can choose the following two ways to design:
1. You could draw a room as the garden, select the wall in the plane view, adjust the height of the wall in the "Basic Parameters-Partial" on the right panel, and then lower the wall height as the fence.
You could also select "Outside Area" in the "Create Room" section to draw an external area on the canvas. After drawing, you can select the ground for material replacement.
