Who knows how to remove the mouse ticker?
Olga Sosova 10 April
Hi all! Help!
I'm already tired of moving it! A lot of time is wasted on this, and it’s starting to irritate me a lot!
She returns after each movement, blocking the view of the work.
0 177 3
Comments(3)
Olga Sosova 19hr
This is not a problem with the mouse cursor, it is on the site itself. The IT specialists attached it to the center, but it was a disaster for me! Wasting my time pushing her away@ Homestyler support
Hello! It sounds like you're experiencing issues with your mouse cursor. Here are some general steps you might consider: Check your mouse and touchpad settings in your control panel or system settings. Look for any settings that control cursor behavior and see if anything seems unusual or turned on by mistake. Update your mouse/touchpad drivers. Go to the device manager, find your mouse, and check if there is an update available. Try disconnecting the mouse and reconnecting it if you are using an external one. Try restarting your computer to see if that resolves the issue. If you have another
Olga Sosova 10 May
Constantly getting in the way! And if you work even closer, then the work lasts 3 times longer, because it must be pushed back every time. I am angry!
Homestyler support 10 April
