I wanna create a custom circle opening on the wall , please give instruction on it .have been stuck on it , I could do it earlier but It is not happening anymore
Either use 3D model. Or make a wall using custom modeling. Change height of the wall, in custom modeling create a plane the size of the wall. Use guidelines to create a square, divide the square in equal parts and then use the circle tool from the center point. Delete the circle and then extrude to the width of the wall. In the design interface move the model into place, matching it to wall. You can do the same thing using the door opening to create a shape window. Just keep in mind the materials you are gong to use, patterns will not be easy to match.
