How to render when I want to set camera behind the wall???
Wun Yan Fung 6-5
As I want to render a wider picture, I want to put the camera behind the wall.
And I try to hide the wall and then press render, but that area will become very bright?
That is not my expected picture.
Does anyone have other way to render a wider picture with only the lighting inside the house? Thanks
0 867 2
评论(2)
Elizabeth J 6-7
Did you try adjusting the FOV?
1 回复
Wun Yan Fung 6-7
Thanks for reply! I have adjusted the FOV but the image what I want is the picture attached...but thank you for your suggestion!@ Elizabeth J
