Doors and windows visible in 2D, but not in 3D
Anna Berger 5 Juillet 2022
Hello,
my problem is that some of the windows and doors are not showing in the 3D model. Whats the solution to this problem?
Thanks in advance
0 139 1
Commentaires(1)
Grace Simmons 7 Juillet 2022
Its a glitch. Try these things: moving the window & then moving it back, delete & reinstall window, in plane view check to make sure the window is aligned with the wall. Check to make sure that there is no custom wall feature. As a last resort delete the wall and redraw it & place window again. Keep in mind it might actually be the window. Some HS windows do not install right. Good Luck.
