Wall Measure - BUG?
Aleksandra 2022-5-26
Hi, I think I noticed a mistake. The program measures rooms from the middle of the wall, not from the inside, as until recently. Does anyone have a similar problem? Maybe I don't know about a function and I can switch it somewhere?
0 229 2
コメント(2)
| BlueJay 2022-6-15
Hey, If you go into the 'VIEW' tab up in the top bar and then go into 'DISPLAY SETTINGS' and then go into the top tab called 'DIMENSION' and then you can choose how it takes the wall measurements or if you even want them to appear. Hope this helps. :) (I have attached an image showing what I mean)
役に立った コメントに返信する
Grace Simmons 2022-5-28
It may be a bug caused by the measurement your using. I use feet/inches and my lines go from wall to wall. You picture shows them in the middle. It could be because your using cm/m. Hopefully you'll get a response.
役に立った コメントに返信する
