How to replace the handle or adjust the handle position in Custom Furniture?
Homestyler Official 2022-1-24
In the Custom Furniture interface, switch to the selection mode of "Select Parts" and select the door panel, and you can replace the style of the handle in the right property panel under "Style-Handle Style".替换把手样式2.gif
You can also change the position of the handle under "Style-Handle-Position" in the right property panel, or adjust the position of the handle by modifying the value of "Handle Margin".更改把手位置1.gif
At the same time, you can also double-click to select the handle, and modify the margin value on the positioning line to adjust its position.
0 1620 2
評論(2)
Luciana Patrícia Silva Nobre 4-8
vídeos rápidos, poderia ser mais lentos
sawliks 2022-6-24
I need a corner cabinet with handle 76. How to add this kind of handles?
