How to draw the countertop area with Custom Furniture?
Homestyler Official 2022-1-24
Instead of selecting cabinets and generating countertop automatically, you could also draw the countertop area.
Select the "Straight Line" above, and then left-click to select the starting point. During the drawing process, you can manually enter the size.手动绘制台面1.gif
After the drawing is complete, click "Generate" below to generate the countertop. After generating the countertop, you can adjust its basic properties like thickness, apron trim or backsplash height and elevation, as well as styler properties like material in the right property panel.
0 1984 3
評論(3)
lewislaneinteriors 2022-6-28
What if the countertop is round
1 回複
Norbert Mészáros 1-30
I assume you have to follow the curvature with the line tool. Not the best though.@ lewislaneinteriors
Tatiana Arkhangelskaya 2022-7-19
how to remove countertop apron???
