Added 540p and you can spend points for it,and more
Homestyler Official17 March 2022
Floor Planner 08/2021 Release Notes - 【Video Render】 related updates
1.Video resolution added 540p and you can spend Homestyler points for it
2.Support directly drawing curved path and straight path
3.Video rendering added advanced mode
Detailed tutorial :
4.The lamps support brightness change animation in video
0 1257 0
