1.Added model grouping list
2.Supported automatic grouping after using the array function
Array function is a common function in modeling. However, previously we have to regroup the models after each use. This update will automatically group all the models after the array, which make it more convenient.
3.Supported 3D text wrapping input, and move and rotate freely
