How to add moldings to the shape?
Homestyler Official 2021-2-21
Click "Customize-Customize Wall" and select the wall to enter the customize wall interface.
In the left "Assembly-Molding" catalog, select the style of the molding and then select the modeling line or surface to add moldings. Hold the "Ctrl" key (⌘ key for Mac)) to switch between adding molding by segments or by a whole circle. After adding, select the molding and you can adjust the size, the position and the style of the molding in the right property panel.
0 2349 3
评论(3)
danfaltyn 10-31
You have a video with no explanation or instructions.
1 回复
Alonzo Klimentos 3 小时前
When I apply wood molding as trim from ceiling to floor it overlaps the baseboard. It looks horrible. How do I make it stop at the baseboard?
danfaltyn 11-5
Video too fast and lack direction
