How to change the room type and room name?
Homestyler Official 2021-2-17
Switch to the 2D plane view, select the room and change the room type in the "Room Type - Current Type" on the right side. Once you have finished modifying the room type, you can also manually enter the name for the room in the box on the right.房间名称修改.gif
0 7397 7
コメント(7)
Lukas; Kral 2022-6-29
20 コメントに返信する
garciarodriguez.nieves 2023-2-7
4 コメントに返信する
OLAIYA A 2023-1-7
If you go to the model library and add any object (you can just delete it after), then try again. The focus shifts from the ceiling and the correct option should be there on the right. I was having the same problem and randomly tried this and it works@ Lukas; Kral
1 コメントに返信する
thall272 2022-4-20
Stairs
1 コメントに返信する
CR Lueker 9-10
I'm trying to change room name and type. It is not possible, what is on my screen looks nothing like the video
役に立った コメントに返信する
Rebecca Cartwright 2022-11-29
As the other comment states there is no option to change the room name, just edit and adjust the ceiling.... please respond in english on how this can be fixed :)
役に立った コメントに返信する
igor.kochkin991 2022-9-8
Точно такая же ситуация, подскажите как сделать.@ Lukas; Kral
役に立った コメントに返信する
