How to change the room type and room name?
Homestyler Official 17 Febbraio 2021
Switch to the 2D plane view, select the room and change the room type in the "Room Type - Current Type" on the right side. Once you have finished modifying the room type, you can also manually enter the name for the room in the box on the right.房间名称修改.gif
0 7401 7
Commenti(7)
Lukas; Kral 29 Giugno 2022
20 rispondere
garciarodriguez.nieves 7 Febbraio 2023
4 rispondere
OLAIYA A 7 Gennaio 2023
If you go to the model library and add any object (you can just delete it after), then try again. The focus shifts from the ceiling and the correct option should be there on the right. I was having the same problem and randomly tried this and it works@ Lukas; Kral
1 rispondere
thall272 20 Aprile 2022
Stairs
1 rispondere
CR Lueker 10 Settembre
I'm trying to change room name and type. It is not possible, what is on my screen looks nothing like the video
Rebecca Cartwright 29 Novembre 2022
As the other comment states there is no option to change the room name, just edit and adjust the ceiling.... please respond in english on how this can be fixed :)
igor.kochkin991 8 Settembre 2022
Точно такая же ситуация, подскажите как сделать.@ Lukas; Kral
