How to make an opening in the floor?
Homestyler Official26 January 2021
Select "Create Room-Structure-Floor Opening" in the left list and drag it into the scene to make a hole in the floor. After the hole has been opened, you can adjust the size and position of the opening in the 2D plane view by dragging directly, or adjusting the size value in the right property panel.楼板开洞.gif
0 3604 16
Comments(16)
Juyeon Cisauk26 July
yeaah me too, no floor opening.@ lisabecka
There is no floor opening option in my Homestyler. Next to Cylinder there's just Sunken Ground and so on.
7 Reply
Tania Bertholdi27 January
My room is odd shaped - not square, so cannot open a hole using the Floor opening tool. Please help.
5 Reply
Vidir Geirsson29 July
So you need to go to edit floor and then you click the option rectangular floor opening@ lisabecka
3 Reply
Mariya Klimchenkova27 July
How to make an opening in the floor in V 5.0?
3 Reply
John Dada23 August
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ Juyeon Cisauk
why dont i have floor opening in the version?
1 Reply
helenagomesaraujo989 September
Não me aparece essa opção de "FLOOR OPENING"
John Dada23 August
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ lisabecka
John Dada23 August
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening@ Mariya Klimchenkova
John Dada23 August
John Dada22 August
can't open the design you started in V5 into the V4...@ Gina Manolea
go back in V4
Gina Manolea27 July
go back in V4@ Juyeon Cisauk
Gina Manolea27 July
go back to V4@ Tania Bertholdi
Gina Manolea27 July
you need to work in V4 for this option@ Juyeon Cisauk
lisabecka19 July
Rey5 May
Is there a way to lock the openings? Mine keep moving to the 1st floor every time I reopen it.
