Homestyler Official 8 Marzo 2022
1 .The central canvas
2 .The left catalog
3 .The top toolbar
4 .The right property panel
5 .The bottom toolbar
You are able to zoom in and out with your mouse curser.  In addition, in 3D view you are able to move around by clicking on the four arrows on the bottom of the screen, and look around by clicking and dragging the left button of your mouse. Alternatively, we also  provide hotkeys W, S, A, D, or the four arrows on the keyboard for a more spontaneous walk-through manipulation.
2.【The Left Catalog】There are five modules in  the left catalog area - Create Room, Customize, Autostyler, Model Library, and My  Folder.
2.1 Create Room
2.11 You could create rooms by opening a template  design, importing a floor plan as image or CAD file, or directly sketch the floor plan.
2.13 Add different types of doors and windows, and add  building structures like openings, beams or columns.
2.2 Customization
2.22 Custom Furniture allows you to easily customize kitchen cabinets, wardrobe                and shelves with our furniture and parts catalog.
2.3  Autostyler
Autostyler decorates the rooms for you based on the template you choose. After you created rooms, click "Autostyler" and select a satisfactory  project to apply. You could choose to apply the whole house design, or a single room design to your rooms. After applying, you can also adjust the position or size of the furniture to make it more suitable for your room.
2.4 Model Library
2.42 Structure/Catalog/Finish: You could find over 100,000 models and materials in the Homestyler model library, like building elements, floor and wall paint, furniture in different kinds of spaces, plants and animals, exquisite home decoration, etc.
2.5 My Folder
My Uploads: You could find your own uploaded 3D models and images in this folder. You can also find the customized models you made with Interior Modeling and the grouped models in Model Combination.
3.1 Top left corner:
3.2 Top middle part:
Common toolbars including operation settings, material brush, tools drop-down menu, hidden and view,  export and render.
3.3 Top right corner:
4.【Right Property Panel】In the property panel,  you can select different objects like furniture or finishes, and then you could set parameters of basic properties or style properties to meet your custom needs.
4.1 Room Navigation Viewport:
4.2 Property Panel:
· The stairs icon: Add or delete floors or basement
· The selection box: Switch the current floor level, so that you could draw rooms and decorate on each floor separately
· The checkbox: Set whether to show all floors or display each floor separately
Other posts for beginners:
2. Create the floor plan
3. Decorate the rooms
4. Render beautiful images
0 46230 21
Commenti(21)
Patrick Pryor 7 Febbraio 2022
chicken sandwich
9 rispondere
rcarpi41 26 Settembre 2022
Buon giorno è possibile tradurre la pagina in italiano ? Grazie
4 rispondere
Prescott Greenwood 21 Marzo 2023
chicken sandwich@ Patrick Pryor
chicken sandwich
1 rispondere
Barbara Berta 20 Aprile
Where are the video tutoials?
Ирина Трубина 26 Marzo
anecia-1987 22 Marzo
Maria Plestsova 18 Marzo
хорошо!
Светлана К 16 Marzo
chicken sandwich
Lenar Basharov 8 Settembre
во
Nataliya Sedneva 7 Agosto
БЛАГОДАРЮ ЗА ОБУЧЕНИЕ
yanisleidispisonero 14 Maggio
muy buena la explicacion
Jorim Mckinney 2 Febbraio 2023
im required to have this software
4home_ds 19 Gennaio 2023
все понятно
Ethan Seiple 2 Dicembre 2022
is it just me and my bad laptop or is that a 2D version if so where can i get it
Raimundo Oliveira 29 Ottobre 2022
Rick Martinez 24 Agosto 2022
I have a we buy houses business that I think can really utilize this tool. Sometimes its hard to visualize a house after rehab. Can I take a rendering like a panoramic and embed it on my Tulsa house buying business site http://sellyourhousetulsa.com
Dani Macri 27 Luglio 2022
How can I set the name of a room?
thomas.meiller2810mail 17 Febbraio 2022
very nice and detaled description send a hug
asiaxoreva 12 Febbraio 2022
ok@ cri_lc
good enough! hope to have understand right...my english is not so good! but seems to me an intuitive approach...so...try and draw! :)
Homestyler Official 8 Febbraio 2022
Practice makes perfect~ You could start by joining our interesting weekly design contest~ Hope you enjoy designing with us!@ cri_lc
cri_lc 4 Febbraio 2022
