AI Planter Tutorial:
AI Planter is a feature inside the Outside Area section. Click Outside Area to enter the tool interface.
The AI Planter tool is on the top-right side of the interface. Click it to open the tool panel.
Use the drawing tools to outline an area. The plants will be generated based on the area you draw.
 We suggest keeping the area under 2500 m² and the total number of plants under 3000.
Step 1: Select Plant Style
It has a full set of plant templates that you can use to choose different styles.
Step 2: Plant Density
It includes four layers: groundcover, low shrubs, high shrubs, and trees.
 You can control the visibility of each layer and adjust the plant density.
Step 3: Choose different arrangement modes
Linear: Plants are generated from one side of the selected area to the opposite side.
Radial: Plants are generated from the center of the selected area and spread outward in all directions.
Tile: Plants are generated from the house as the starting point and spread outward.
Step 4: Click to generate
Click to select the area, then click Generate to create the plants.
After the plants are generated, the view will switch to 3D automatically for easier viewing.
Click Complete Outside Area to exit and move on to rendering.
