1 .The central canvas
2 .The left catalog
3 .The top toolbar
4 .The right property panel
5 .The bottom toolbar
You are able to zoom in and out with your mouse curser. In addition, in 3D view you are able to move around by clicking on the four arrows on the bottom of the screen, and look around by clicking and dragging the left button of your mouse. Alternatively, we also provide hotkeys W, S, A, D, or the four arrows on the keyboard for a more spontaneous walk-through manipulation.
2.【The Left Catalog】There are five modules in the left catalog area - Create Room, Customize, Autostyler, Model Library, and My Folder.
2.1 Create Room
2.11 You could create rooms by opening a template design, importing a floor plan as image or CAD file, or directly sketch the floor plan.
2.13 Add different types of doors and windows, and add building structures like openings, beams or columns.
2.2 Customization
2.22 Custom Furniture allows you to easily customize kitchen cabinets, wardrobe and shelves with our furniture and parts catalog.
2.3 Autostyler
Autostyler decorates the rooms for you based on the template you choose. After you created rooms, click "Autostyler" and select a satisfactory project to apply. You could choose to apply the whole house design, or a single room design to your rooms. After applying, you can also adjust the position or size of the furniture to make it more suitable for your room.
2.4 Model Library
2.42 Structure/Catalog/Finish: You could find over 100,000 models and materials in the Homestyler model library, like building elements, floor and wall paint, furniture in different kinds of spaces, plants and animals, exquisite home decoration, etc.
2.5 My Folder
My Uploads: You could find your own uploaded 3D models and images in this folder. You can also find the customized models you made with Interior Modeling and the grouped models in Model Combination.
3.1 Top left corner:
3.2 Top middle part:
Common toolbars including operation settings, material brush, tools drop-down menu, hidden and view, export and render.
3.3 Top right corner:
4.【Right Property Panel】In the property panel, you can select different objects like furniture or finishes, and then you could set parameters of basic properties or style properties to meet your custom needs.
4.1 Room Navigation Viewport:
4.2 Property Panel:
· The stairs icon: Add or delete floors or basement
· The selection box: Switch the current floor level, so that you could draw rooms and decorate on each floor separately
· The checkbox: Set whether to show all floors or display each floor separately
Other posts for beginners:
