How to design the outside area?
Homestyler Official 2021-1-26
You can choose the following two ways to design:
1. You could draw a room as the garden, select the wall in the plane view, adjust the height of the wall in the "Basic Parameters-Partial" on the right panel, and then lower the wall height as the fence.
You could also select "Outside Area" in the "Create Room" section to draw an external area on the canvas. After drawing, you can select the ground for material replacement.
0 10187 5
コメント(5)
Andrea Harmina 2022-11-5
after external area created - partial the wall - how can I remove-delete the roof??
13 コメントに返信する
Туйаара Федорова 2022-6-6
How do I increase the outside area size, than 100*100 meters?
8 コメントに返信する
Anabella Bustamante 2022-8-23
te respondieron? como hacerlo?@ brooklyn kingi
how do i place the grass down
2 コメントに返信する
Irina Datcu 10-4
Hi, if I use OUTSIDE area to create the yard, what exactly do I need to do? there is any trick because I try ro draw but it doesn't really work. I've managed to do an small area BY MISTAKE but if I want to select the correct area that i need is not working
役に立った コメントに返信する
brooklyn kingi 2022-8-3
役に立った コメントに返信する
