Please check whether you have openings on your wall and whether the room has light sources. You could also choose a pre-set lighting template or customize your own lighting. Also please check whether your camera is in the wall from the window inn the upper right corner.
Porque mi render queda de esta manera? con otro proyecto no tengo problema, pero con el diseño de este proyecto si.
