TRANSPARENT GLASS DOES NOT RESPOND
ESTER -DESIGN 2021-10-23
Hi guys I have a problem with material and glass: in the preview of the render I see it transparent, when the render is finished the glass becomes opaque white, why?
thank you very much to those who want to help me and have a nice day :-)
Ester
0 1756 5
评论(5)
Grace Simmons 2021-11-3
There are several glass materials in HS inventory that look clear but actually are not. Try Clear Glass 25 under premium>glass>ordinary glass.....it is close to the end around page 7/8....not quite sure, I put it in my favorites so I can always find it! It shows a greenish color in design interface but always renders clear
4 回复
Maria Jose Samper 9-19
Hello, I´ve been trying to apply this clear glass 25 to a shower door, but it still doesn´t work. How can i get a clear glass?@ Grace Simmons
2 回复
Grace Simmons 9-19
Looks like you are using the HS shower door. This model does not take the clear glass material. Try using Glass Partition1/2 either one will change one has a frame and the other doesn't. Both are clear glass already.@ Maria Jose Samper
1 回复
iwona.alicja.targosz 12-7
This works! Thanks so much for your advise.@ Maria Jose Samper
ESTER -DESIGN 2021-11-3
thanks a lot Grace,to make good :-)
