How to stage on an existing photo?
veronica 2021-10-19
As a newbie, I'm trying to put furniture an existing photograph of an empty room. The only option I found is to draw rooms from starting with a floorplan. Can it be from an existing room? I hope that makes sense:)
Below is the room I want to stage.
Thanks
0 3130 9
评论(9)
Levi Aldom 2021-10-27
Since Homestyler isn't helping you I will. If you download the home styler app you can take a picture of the room and add furniture to the picture. This does not work on the web version.
6 回复
Homestyler Official 2021-10-21
Hi check this link: https://www.homestyler.com/openShared?assetId=cec9e9ae-9246-45c7-80b4-c86d71245fda@ veronica
You keep repeating the same answer but don't answer to my post. Can ou please answer? How can I stage the exact photo I upload? Is it possible on your desktop version? I need to stage with furniture ON the photo. You mention the mobile app. What I'm asking is: Is it possible on your desktop version? I need to stage with furniture ON the photo. Thank you
1 回复
For this kind of simple room, you could build a simple room within 5 minutes, like the one I just sent you. But no, you cannot drop furniture on a picture because web version design needs to be based on a 3D space.@ veronica
Can you simply answer if dropping the furniture on a photo would work on the desktop version or is it just on the mobile version?
veronica 2021-10-21
oh well...
veronica 2021-10-21
Can you simply answer if dropping the furniture on a photo would work on the desktop version or is it just on the mobile version?@ Homestyler Official
Hi, you can either stage with the photo on our mobile app (access through "shoot and design" from the top), where you could drag and drop furniture in the room. Or you could rebuild the space in our web version(simply draw a rectangular room, and then replace material of walls and floor): 3d.homestyler.com
veronica 2021-10-21
You keep repeating the same answer but don't answer to my post. Can ou please answer? How can I stage the exact photo I upload? Is it possible on your desktop version? I need to stage with furniture ON the photo. You mention the mobile app. What I'm asking is: Is it possible on your desktop version? I need to stage with furniture ON the photo. Thank you@ Homestyler Official
veronica 2021-10-21
For the web version, do I need to draw a floor plan? I'm a real estate photographer and need to work from the photos I take, on my desktop (not on mobile). How can I stage the exact photo I upload? Is it possible on your desktop version? I need to stage with furniture ON the photo. From what I see, I can only start by drawing floorplans but I want already have the room. Thanks@ Homestyler Official
veronica 2021-10-19
Homestyler Official 2021-10-19
