How can I change the unit from mm/m to ft?
You can click the Setting icon in the upper right corner to open the Preferences window. Also, you can change the measurement unit between mm/cm/m and ft through "File - Preference - Measurement Unit" in the top navigation bar in the design interface of the floor planner.
(This was from the top menu-- "Learn"> FAQS) Hope this helps!
Utile
rispondere
ekaterine kurdadze24 Settembre 2021
thank you so much. this really helped.@ Melissa D
Utile
rispondere
Melissa D24 Settembre 2021
Utile
rispondere
