AI Planter is a feature that auto generate plant arrangements based on the area you select, as well as the plant combination style, density, spread mode you choose. This feature is inside the "Outside Area" environment under the "Build" section. Click "Outside Area" to enter the tool interface.
The AI Planter tool is on the top-right side of the interface. Click it to open the tool panel.
Use the drawing tools to outline an area. The plants will be generated based on the area you draw.
We recommend keeping the area below 2500 m² and the total number of plants under 3000 to ensure smooth browser performance and avoid overload or lag.
Step 1: Select Plant Style
It has a full set of plant templates that you can use to choose different styles.
Step 2: Plant Density
It includes four layers: groundcover, low shrubs, high shrubs, and trees.
You can control the visibility of each layer and adjust the plant density.
Step 3: Choose different arrangement modes
Linear: Plants are generated from one side of the selected area to the opposite side.
Radial: Plants are generated from the center of the selected area and spread outward in all directions.
Tile: Plants are generated from the house as the starting point and spread outward.
Step 4: Click to generate
Click to select the area, then click Generate to create the plants.
After the plants are generated, the view will switch to 3D automatically for easier viewing.
Click "Complete Outside Area" to exit and move on to rendering.
Video Tutorial:
You can also check out our step‑by‑step video tutorial here, perfect if you prefer learning by watching rather than reading:
[Watch the AI Planter Video Guide >>]
