When I use the ruler tool using imperial measurements (feet & inches), it only displays down to the inch. I'm wondering if there is a way to see fractiions or decimals for precise measurements. For example, if I want a plinth block to be a half inch wider than a piece of trim but both display as 5" rather than the plinth block displaying as 5.5". Precise measurements are pretty critical in a lot of situations. It's the same in all views as well as when doing interior modeling. The guidelines tool is the same unless I manually enter the measurement to set it. Any help is greatly appreciated!
