Content Overview:
1.Copy a Single Room
2.Copy an Entire Floor Plan
3.Copy a Room with Furniture/Materials
4.Effortless Creation of Multi-Shape Rooms
Select the room, then click "Copy Room".
Place the copied room in the desired location. Press ESC or right-click to exit the command.
If rooms overlap, the overlapping area becomes an independent room (see example).
To copy a floor plan, go to "Construction > Copy Plan".
Select the area to copy (the green highlighted area indicates the copyable range).
Place the copied floor plan in the desired location. Press ESC or right-click to exit.
Room structure (walls, doors, windows) is copied automatically.Furniture/materials are NOT copied by default.
To duplicate furniture/materials:
Select individual items and click "Duplicate", or Hold Shift to select multiple items, then click "Duplicate".
In bulid-draw rooms, you can choose rooms of different shapes for quick creation
