Hello, is it posible to import a complex 3d blocks from Acad? let`s say that is an already made scene with a kitchen furniture , using Homestyler just for rendering .Thank you in advance
Hello,
we suggest you to delete all the extra informations inside the house, just remain the main structure, and the walls should be made with double lines but not single line or too many lines,
also the measurement should be with 'mm' , and each time, you can only import one floor plan on each floor:)
