Brother Printer WiFi Setup 8️⃣8️⃣8️⃣9️⃣6️⃣6️⃣6️⃣0️⃣9️⃣7️⃣  Call Us  | Easy Methods
Brother printer accepts text and graphic output from a computer and transfers the data to paper. It is capable of creating high-quality documents and photos. And being capable of printing wirelessly, it is quite convenient.
Brother printer allows you to print wirelessly, but there are many users who don’t know how to connect Brother printer to WiFi. If you are also from the same category, then this destination is the best fit for you.
In the digital generation, you cannot neglect the importance of wireless technology. The procedure of connecting the Brother printer to WiFi might appear straightforward. But it is not in actuality, especially for those, who are non-technical.
However, as compared to other companies’ printers, Brother has made this job straightforward for you with easy-to-use wireless printing. If unable to do the Brother printer WiFi setup on your own, then follow the below instructions.
Steps for How to Connect Brother Printer to WiFi
If you are tired of fumbling with a tangled cable and racing to plug it into your laptop. Through the Brother printer WiFi setup, you can print, scan, and copy effectively from any intersection of your residence. Follow the below steps to connect your Brother printer to the WiFi network.
1. Draft your Network Information
Before proceeding and jumping to further steps, first, you need to gather some information. Pieces of information like the name of your WiFi network (SSID) and the password of the WiFi network.
2. Turn on the Brother Printer
Once gathered the required information, you now have to turn on the Brother printer. To turn the printer on, plug the power cord of the printer into the wall socket.
3. Access the Control Panel
After turning the printer on, you need to access the control panel of the Brother printer. The control panel includes pressing buttons or navigating a touchscreen interface for Brother printer WiFi setup.
4. Enter the WiFi Setup Mode
On the control panel of the Brother printer, go to the Network or Settings menu. After that, choose the option WLAN or the WiFi. Then choose Setup Wizard or any similar option to connect the Brother printer to WiFi.
5.  Choose your Network
Now your Brother printer will search for available WiFi networks. After this, from the list choose your network, when prompted for the Brother printer WiFi setup.
6. Enter your WiFi Network Password
Once you have recognized your network, now you will be prompted to enter your WiFi network password. Be careful while entering the WiFi network password by using the control panel of the printer. Also, verify the password for accuracy.
7. Confirm Your Connection
Now your Printer printer will attempt to connect to your WiFi network. Once you have successfully connected, you will notice a verification notification in the control panel of the Brother printer.
8. Install the Brother Printer Software
To appreciate a seamless printing venture from your computer. You have to install the Brother printer software for the Brother printer WiFi setup. Also, you can easily get it from the official website of the Brother printer and follow the on-screen instructions.
9. Test the Connection
Once you have done all the above steps. Now confirm that the Brother printer is connected properly. Test the connection between the printer and the WiFi network by taking a test print. If the page gets out without any problem, then it means you have successfully connected your Brother printer to WiFi.
How to Troubleshoot Issues while Brother Printer WiFi Setup?
While the Brother printer WiFi setup, many users have reported that they are having problems. To avoid such issues, follow the below troubleshooting resolutions.
If you encounter any issues while setup, you need to verify your network credentials.
Make sure your printer and the WiFi router are in the range of the WiFI range for Brother printer WiFi setup.
Also, ensure that the Brother printer firmware is updated to its latest version.
Brother Printer WiFi Setup FAQs
1. How Can I Connect My Printer to the WiFi Network?
To connect your Brother printer, turn on the printer and connect it to your WiFi network. For this, you should have a working WIFi network and password.
Also, make sure your computer is on the same network for printing wirelessly. If using iOS, use AirPrint to print wirelessly and for Android, it lets you choose a default printer.
2. How to Update Brother Printer Firmware?
First take a test print from the computer, to check if it can print. Then download the Firmware Update Tool and click on downloaded files. After this, follow the on-screen instructions, choose your printer name from the list, and click on Next. Now click on continue and follow the on-screen instructions. If prompted, enter the printer password and click on OK.
3. Why Updating the Firmware Required?
Updating the firmware on time can improve the functionality, security, and features of your device. This also helps in fixing the issues within your printer, installing new features, and helping your device compete with newer models.
4. Where is the Password of My Brother Printer Written?
The default password of the Brother printer is located on a sticker on the printer itself. The sticker is on the back or bottom of the printer or in the user manual of the Printer.
Sum up
If you find Brother printer WiFi setup a complicated job, simply go through the above steps. Certainly, the provided instructions will help you with how to connect Brother printer to WiFi.
