"I don't understand how to remove these three light reflections in the render of this living room. It seems that the problem stems from the ceiling; indeed, if I remove it and try to launch the render, there are no reflections, but the image appears much duller. How should I proceed?"
Go to render interface, then click on 'Add Light' choose the template you are using and then got to 2D view and delete the light. Then save the template and remember to use it every time you do a render. This video shows how to get to correct place: https://www.homestyler.com/forum/view/1694640574205632513?spm=a1zmxy.22532806.0.0.39be71ceJSmUNc Once in the right place you can just delete the light.
