Hi, everyone! Is it possible to paint customized cabinets with colors using HEX codes?
When I try to change their colors, i go to replace material --> style --> wood ---> plate material --> paint ---> painted panel, but it only shows few options for colors and won't allow me to customize using HEX codes. Thanks for helping out
Pt 1:You can use hex/RGB colors on anything. You need access to an art type program: Affinity photo, Clip Studio Paint, Corel or something like that. Once you have the hex/rgb code you need to create a jpg file with only that color covering the whole page. Save the jpeg to laptop, upload the file as a 2D texture as a custom map, use the jpeg dimensions in the upload box. When done you will be able to apply to anything. For any other model-use replace material function to apply.
