Does anyone know how to create lines to make parking spaces???? If so please help. <3 (:
You can use a 3D model or you can create the parking lot yourself. In HS go to 'tile flooring' and use the line/ rectangle tools to draw the lines/spacing and then fill in with the appropriate textures. If you created an a custom model its the same thing just using custom model tools and then apply textures. I'm not sure how it will work if you used the 'outside space' tool. I stopped using it because it lacked design capabilities.
