A man with erectile dysfunction (ED) struggles to achieve or maintain an erectio*. The disease makes it impossible for the guy to start or complete se*. Impotence used to be the name for this ailment. Although ED can strike at any age, men over the age of 75 are more likely to experience it.
Ageing need not be associated with ED. A guy may require more stimulation as he ages in order to achieve an erectio*. He may also require longer intervals between erectio*s. Men who are older should still be able achieve erectio* and have se*.
What causes erectile dysfunction?
Causes of erectile dysfunction include:
·         (High blood sugar) Diabetes
·         High blood pressure, or hypertension
·         Artery stiffening, or atherosclerosis
·         Stress, worry, or sadness
·         Tobacco and alcohol use
·         A few prescription drugs. Antidepressants, painkillers, and blood pressure medications fall within this category.
·         Fatigue
·         Damage to the brain or spinal cord
·         Low levels of testos*, the male hormone, are a symptom of the illness known as hypogonadism.
·         A number of sclerosis
·         Parkinson's condition
·         Testicular radiation treatment
·         Stroke
·         Various prostate or bladder surgeries
Erectile dysfunction can also be brought on by issues in your se*ual partnership. Your se* life may benefit from improving your connection. If you choose to go to therapy, including your se* partner will undoubtedly make it more effective.
Couples might pick up new tricks for cajoling and courting one another. This can help to lessen anxiety related to erectio*s.
Erectile dysfunction can result from certain emotions, such as:
·         Feeling uneasy about having se*. This can be the result of a negative encounter or a previous ed episode.
·         Stressed out, including stressed out about work and family.
·         Feeling down and out.
·         Feeling embarrassed by your appearance or your performance.
·         Believing your partner is being hostile to you.
Erectile dysfunction causes:
ED may have a variety of emotional and physical issues as one of its causes. These are typical physical causes:
·         Cardiovascular disease
·         Diabetes
·         Hypertension, or high blood pressure
·         High cholesterol
·         Hypothyroidism
·         Low testos* levels or other hormonal abnormalities due to obesity
·         Renal illness
·         Rising age-related relationship issues
·         Certain prescription drugs, like those used to treat depression or high blood pressure
·         Sleep problems
·         Drug
·         Overindulging in booze
·         Consuming tobacco products causes liver cirrhosis and epilepsy
·         Damage from multiple sclerosis to the pelvic region as a result of trauma or surgery
·         Peyronie's disease, which results in the development of scar tissue in the peni*
Typical emotional triggers include:
·         Challenges in relationships,
·         Stress,
·         Anxiety, and
·         Sadness
One of these causes alone, or a combination of them, can result in ED. To help your doctor rule out or treat any underlying medical concerns, it's crucial to cooperate with them. Find out more about the origins of ED.
How is erectile dysfunction diagnosed?
ED is typically simple to identify. Speak to your doctor if you are inclined to self-diagnose. They'll check to make sure it's unrelated to any other medical issues.
Your doctor will examine you physically and inquire about your problems. They might perform a urin* or blood test. To rule out any conditions, your doctor might seek additional tests.
Can erectile dysfunction be prevented or avoided?
Whether you are aware of the root cause of your ED will determine this. You can take a few steps to possibly avoid ED, such as:
Avoid using  smoking, or excessive alcohol consumption.
If you take any new or existing medications, inquire with your doctor if ED is a possible adverse effect. He or she might use alternative treatment.
Maintain proper blood pressure and sugar levels.
Try to unwind and be stress-free.
Erectile dysfunction treatment:
What is causing it determines how to treat it. Take your medication as directed by your doctor if it is caused by excessive blood pressure or uncontrolled blood sugar.
Your doctor may recommend men’s health pills Sildenafil (brand name: Viagr*), Tadalafil (brand name: Cialis), and Vardenafil (brand name: Levitra) if all other potential causes have been ruled out. You can maintain an erectio* by taking these medications orally.
It can be injected into the peni* or put into the urethra (the hole at the end of the peni*) as a tiny suppository. Which treatment is best for you will be determined with the advice of your doctor.
Even if you take the medication, you still need to be active and mentally engaged in order to feel the need to erectio*. Call your doctor if the first dose doesn't work. Your doctor might decide to alter the dosage of your medication.
Most ED medications have similar side effects. Vardenafil with sildenafil may result in:
·         Headache
·         Flushing (warming and reddening of the face and upper body)
·         uneasy stomach
·         clogged nose
·         Things become blue when your vision changes.
With the possible exception of flushing and visual problems, tadalafil has the same side effects. Back pain and muscle aches might also result from it.
Headache is the most frequent adverse reaction to each medication. The least frequent changes are in vision. If you experience any side effects, let your doctor know.
If you take one of these drugs and experience an extended erectio* that lasts four hours or longer, call your doctor straight once. If left untreated, this disease could result in irreversible impotence.
