Batch Extrude
Batch Ungroup
Batch Subtract
2)Duplicate the grouped cylinder to make a cylinder array (with linear array command, or simply copy and paste with shortcut keys Ctrl+C and Ctrl+V). Afterward,  hold the Shift key to multi select all cylinders, then group again.
