V.5.0-Support importing multi-floor DWG files and alignment settings for floors.
Homestyler Official 19 Mars 2023
Updated Functions:
Detailed Introduction:
0 14362 2
Commentaires(2)
Homestyler Official 19 Septembre
V4.0 will be fully switched to 5.0 soon. So just stay in 5.0 and use it~@ Judith WILLIAM
How can i continue to use the 5.0 beta verison ?
1 Répondre
Judith WILLIAM 15 Mai
