V.5.0-Structure Model supports rotation, tile flooring and other functions
Homestyler Official 2023-3-19
Dear Homestyler users, we are pleased to announce the launch of a new version, Homestyler V5.0. The following is a preview of new features on Structure Model.
Updated Functions:
1. External area supports dragging in the Floor Opening and Sunken Ground models
2. The model of Floor Opening and Sunken Ground added the function of rotation
3. Flue, Square Column, Cyinder and Riser models support tile flooring customization function
Detailed Introduction:
Add the models of Floor Opening and Sunken Ground in the created external area to meet different design requirements
In the plane view (shortcut key: 1), select the model of the Floor Opening and Sunken Ground, which can be rotated.
Select any of the above models, double-click the model, click "Tile Flooring" to enter, and select the pattern and material you like to apply to the surface.
0 13897 4
评论(4)
Grace Simmons 2023-3-31
Great!!! Now how about adding floor opening/sunken ground in ROUND form. This would be great when using a circular staircase. Would be wonderful if you could place a circular stair in the middle of a room and have an opening on the above floor in the same dimensions as the staircase. Using a square opening & making a custom model with a round hole is a work around but the tiling of floors and the model are difficult to match. Same goes for circular or odd shaped windows. Matching material from the custom model to HS wall just doesn't work. It would give us more design options. @homestyler
5 回复
Grace Simmons 2023-4-19
Flue, Square Column, Cyinder and Riser models DO NOT support tile flooring customization function. Which means when you apply a wood grain texture you CAN NOT change the way the grain is applied. Need to add rotation to change wood grain back and forth from horizontal to vertical. @homestyler
1 回复
Marlene Azevedo 8-1
How do I xhange from " to cm ?
cs-enterprises 7-10
Cs-enterprises is a family-owned and operated kitchen remodeling contractor. We specialize in designing, building, and renovating kitchens. We specialize in designing and installing customized kitchen cabinets, cabinetry, countertops, appliances, and more. Investigate our website for more details.
