V.5.0-Added arc wall drawing, wall alignment and etc. in the floor plan.
Homestyler Official 19 Mars 2023
Updated Functions:
Detailed Introduction:
0 9724 3
Commentaires(3)
Светлана К 27 Mars
ок
Grace Simmons 30 Mars 2023
Can you adjust the customized floor function to work with the curved walls the same way the customized ceilings work with curved walls???????
When converting from Version 4 to V5 wall widths DO NOT MATCH. I use 8" walls and V5 only offers 8.45" so the alignment is off. You then have to redo all of the previous walls to match. Any idea when this is going to be corrected?????
