different floor height
Giovanni Spaggiari 2023-3-23
Hi, how can  design two rooms of the same building  with different floor height?
I can only set different wall height (partial mode) but i do not be able to have two rooms with the ceiling thats separate it from the upper floor
different as well....
Giovanni
0 888 3
评论(3)
valdes.cruzblanca 2023-3-28
I solved making different rooms for each level, with partial walls to match ceiling height
1 回复
Grace Simmons 2023-3-27
Different floor heights can be achieved by using custom modeling. Choose the room and either use custom modeling to make a floor or choose custom floor to create a platform. HS has a YouTube channel with videos or you can look under the 'learn' tab for tutorials.
1 回复
Giovanni Spaggiari 2023-4-3
thaks all....i tried with Grace Simmons method, using modeling and it'ok. I created a hole and fitted with a new model of floor..isnt good ???? ciao Giovanni
