How to create renders of different floors for multi-floor design projects?
Homestyler Official 26 Dicembre 2022
In the latest updates, for all five rendering types (normal image, panorama, aerial view, top view, and video), Hometyler now supports rendering different floors separately for multi-floor projects. Here is the instruction:
1.After you finish the floor planning and decoration of the design with multiple floors, click the "Render" button from the top, and enter the rendering environment.
2.Switch the five rendering types from the top. Take the "Aerial View" as an example, untick the "Show All Floors" option from the lower left corner, then it will only display the current floor level.
3.Switch to the floor level you want, then you could render only the current floor level.
*Note: you could also follow the steps above to switch floor levels and only display one floor level in the design environment first, and then go to the rendering environment to render.
0 4969 9
Commenti(9)
Natalka Nati 6 Gennaio 2023
how can I add a second floor?
6 rispondere
fulgiamm fulgiamm 3 Gennaio 2023
I no longer see the camera cursor. Is it my computer's fault or is it a bad news from the software?
2 rispondere
De Immo Assistent b.v. 31 Agosto
How can i render only 1st and 2nd floor without showing 3 rd floor. I want to render top view with ortho projection and i would like to show also the stairs from 1st to 2nd floor. Is it not possible to select just the desired floors to render? See my uploaded immage
Al'Mari Hunt 18 Gennaio 2023
looks good.
jpzehner 15 Gennaio 2023
The advertisement shows a roof as well, but I don't see it here.
Mason Plumstead 12 Gennaio 2023
om
MIRIAM MC 8 Gennaio 2023
como puedo poner el tejado con sus tejas
Pandemic Ivanoff 28 Dicembre 2022
Ok
Grace Simmons 28 Dicembre 2022
Great Update.....Even thought it has messed up the custom furniture interface. Forum thread: https://www.homestyler.com/forum/view/1607636230428659714
