There are several ways...create your floor plan-making a room that you want as a terrace. In plane view: click on wall and on right side menu choose partial and change the height of the wall. You can go as low as 4" and then put in a railing or change to 3' and use the walls as is. Then click on the same room and change the show ceiling option. If this is a multi story design: go to the upper floor and in plane view, choose the room over the designated for terrace and then in right side menu choose edit floor. Remove the floor, then go back to lower floor and change wall height.
2
Répondre
Ali Ortiz27 Juillet
Wait how do I change the walls to put a railing instead?? Btw thanks for the other info, super helpfull.@ Grace Simmons
Utile
Répondre
H DFH25 Septembre 2022
The Information you shared above is great. https://newjerseyloteryresults.com/ I have been reading all you shared here. In this you explained everything very well. If i want any further guideline we will contact you here. Thanks
Utile
Répondre
Grace Simmons24 Septembre 2022
You can check out HS YouTube channel or put 'Homestyler' in search bar for tutorials. Or you can check out the tutorials under the learn tab of the site. This video: https://www.youtube.com/watch?v=PbnXBmeYXYs&t=1000s.....is kind of an overall look at what you ca do. This is a basic one for editing floors: https://www.youtube.com/watch?v=OVtSta5W4-4&t=5s.....Good Luck!!
Utile
Répondre
Parlez-nous de vous & GAGNEZ 5 Pièces !
Réservez une démo gratuite et discutez avec nos commerciaux
Les plus grandes entreprises mondiales font confiance à Homestyler
