Faces created in Customize Ceiling, Wall, Floor and Tile Flooring support axial array,and more
Homestyler Official18 August 2021
1.Faces created in Customize Ceiling, Wall, Floor and Tile Flooring support axial array.
There are two methods to create the Axial Array: by spacing and by quantity, which can arrange single or multiple ordered shapes regularly and accurately, enabling you to model quickly.
By spacing method for axial array:
1)Select a face (you can hold the "shift" key to select multiple shapes), and left-click "Array-Axial Array". When moving the mouse, the modeling surface will be evenly arranged according to the position of the mouse drag.
2)Enter the X-axis spacing at the top, press the Enter key to confirm the value. Then enter the Y-axis spacing, press the Enter key to confirm again, and then left click on the cavas to end the command.
By quantity method for axial array:
1)Select a face  (you can hold the "shift" key to select multiple shapes), and left-click "Array-Axial Array". Click "Quantity" from the top (or press "Option" to switch between spacing and quantity). Enter the number of X-axis and Y-axis respectively and  press the Enter key to confirm each value (you can switch the X-axis and Y-axis respectively by pressing the tab key) , and then left click on the canvas to end the command.
2.Faces created in Customize Ceiling, Wall, Floor and Tile Flooring support continuous offset.
Select a face and click "Offset". The shape can be continuously offset without repeated arousal of the command. Click the right mouse button (or press Esc) to end the command.
0 1580 0
