Add Boolean operation function in Interior Modeling 2.0,and more
Homestyler Official 18 Agosto 2021
1.Add Boolean operation function in Interior Modeling 2.0
2.Add Batch Operations of Extrude, Ungroup and Subtract in Interior Modeling 2.0
Batch Extrude
Batch Ungroup
Batch Subtract
2)Duplicate the grouped cylinder to make a cylinder array (with linear array command, or simply copy and paste with shortcut keys Ctrl+C and Ctrl+V). Afterward,  hold the Shift key to multi select all cylinders, then group again.
3.Add "Image Recognition" to automatically generate image contour in Interior Modeling 2.0
Interior Modeling 2.0 now supports identifying uploaded image content, converting it into lines and surfaces, and importing it into interior modeling for editing, which is convenient for designing logos, graphics and other elements.
1)Select "Import-Image recognition" on the top toolbar. Then click the left mouse button to select the surface where you need to place the shape, and the image import interface will pop up (please read the image requirements in detail before importing to avoid failure).
2)Click "Upload Image", select the image you need from your computer. You can adjust the value of "Recognition Threshold" in the import panel. After the adjustment is complete, click OK, and the image recognition is completed. Click on the face to place the recognized shape.
4.Support attaching 3D text to arc surfaces
3D text created in Interior Modeling can be attached to the surface model to meet different design requirements. (Note: "Attach To face" currently only supports flat or arc surfaces, but not complex curved surfaces)
1)Select the “Assembly-3D Text” on the left catalog to add text to a face.
2)Use the left mouse button to select the text, click "Attach To face", and then select a flat or arc surface to snap text to it.
5.Add vertical text direction for 3D Text in Interior Modeling 2.0
Interior Modeling 2.0 now supports the creation of vertical and aligned 3D text to meet the design needs of different scenarios such as commercial scenes and storefronts.
1) Enter the Interior Modeling 2.0 interface, add the "3D text" from left catalog to a face.
2)Enter the appropriate text information in the property panel on the right, and select "Text Direction" below to set the direction.
6.Support display of custom furniture models in Interior Modeling 2.0
Custom furniture models can now be displayed in the interior modeling environment, which can assist designers in modeling.
Click "View" on the top toolbar, and check "Show Furniture" to display the furniture model.
7.Support model movement through three axes in Interior Modeling 2.0
In order to facilitate the use of high-frequency operations such as movement and rotation, we have added the function of fast rotation and movement along the X, Y, and Z axes (consistent with the operations of other modules)
1) After creating the model, double-click the shape to group it(shortcut key: ctrl+g).
2) The grouped models support movement and rotation along X, Y, and Z axes (consistent with the movement of furniture models)
8.Support the connection of split segments in Interior Modeling 2.0
Line segments can be custom split and connected in the Interior Modeling 2.0.
1)Split: Left-click on the line, select "Split" and drag the mouse to preview the spacing of the split line segments, or directly enter the exact number of segments in the "Segment Number" below.
2) Connect: Select multiple split line segments by Shift, and click "Connect" to connect the line segments.
0 7194 3
Commenti(3)
Olga Shiryaeva 2 Settembre 2022
Спасибо за такие новые нужные функции в моделировании!
2 rispondere
DaDunLeh 22 Settembre 2022
about time this was updated...great works Homestyler
1 rispondere
HALLE HORNE 25 Settembre 2022
thanks!
