Heelpp
Leila Duarte 2022-8-14
Hello, I would like to know how I can import an image from the internet to the program, such as to use for the walls, the floor or some paintings that the client already has!
0 270 3
評論(3)
Grace Simmons 2022-8-14
For a more detailed tutorial check HS learn page under resources: https://www.homestyler.com/learn-help?spm=a1zmxy.17753989.0.0.7cec3ea0TTXBhM〈=en_US YouTube search bar "homestyler":https://www.youtube.com/results?search_query=homestyler HS very own YouTube channel: https://www.youtube.com/c/HomestylerOfficial
1 回複
Make sure image is high quality, save to hard drive. Right click image for its dimensions, incl these dimensions in the title of image or write down for reference. Go to your HS model inventory, click on '2D models', click on texture, Drag/drop or open image in the interface, click edit choose texture library, then custom map (which will allow adjustments to scale). Put in dimension of image: 1920x1080, 1080x720 DO NOT convert to cm/m/mm/ft/in...click OK. The image will be available to use as texture for anything incl custom modeling/walls/floors/furniture/picture frames/carpets etc
1 回複
Leila Duarte 2022-8-15
Thank you so much <3333@ Grace Simmons
