How to make walls taller/higher
Crivella M 13 Luglio 2022
Hi everyone!, so I was working on a new design and I wanted to make the wall taller. But I did not know how to. Is this possible? and if so can someone tell me how to do it? Thank you!! Have a good day/night.
0 446 2
Commenti(2)
Crivella M 14 Luglio 2022
Ok thank you, I will do that. 😀@ Grace Simmons
Wall heights can easily be adjusted: in plane view use right side menu to change height or go to preferences and chage it there. There are several video tutorials on YouTube: https://www.youtube.com/c/HomestylerOfficial/videos...........Just note that if you are trying to change the height of a specific room, you're going to have to change wall height of design to a higher height & then lower the height of the specific room. With that you are going to have to remove the ceiling from that specific room and create a new one with custom modeling or use a ceiling model.
1 rispondere
Grace Simmons 14 Luglio 2022
