Hi,
When I started using homestyler a few months ago it was easy to change the material scale, rotation, move it horizontally or vertically. Find screenshot below of my old designs and the settings that used to appear. I upload my own materials and i need to customized the walls so it looks like panels.
Now, since the new update i am no longer able to change the material dimensions. As you can see when i click on the material i no longer see those blue dots that appear in the picture above.
Even if i go to to the customized wall section and try to change my material dimensions i can't. As you can see in the screenshot below my material looks blurry and like it has lots of lines but it's not like that. It looks like that because i need to change the dimensions so it will fit in the area properly like i used to be able to do before.
Here is a picture of a design i made months ago. So you can see the material:
Does anyone know to change the material in a customized wall since this program update? Keep in mind i upload my own materials (2d textures) as well.
