Add loft & curved array for modeling,and more
Homestyler Official 2022-3-28
1.Add the Modeling Guide as a beginner's guide to interior modeling
You can go through the modeling guide to gain a basic understanding of the Interior Modeling funciotn. Follow the guided tutorial and use the basic functions to draw shapes, extrude to form a solid, and do detailed modeling with fillet, so as to quickly understand and get started with interior modeling. Click on the modeling guide in the Help menu in the upper right corner anytime if you want a recap, and complete the operations one by one according to the steps and guidance on the screen.image.png
2.Add the Loft modeling function
3.Add the Curved Array modeling function
4.Add the Split function for line segment
5.Add the Component function to modify the same models in batches
1)First create a model or shape, then select the model and click "Component". Then you can duplicate it or make an array for it.image.png
6.Support invert selection command using the shortcut key (Command/Ctrl+i)
The invert selection function can improve the efficiency of model selection. Select one model in the modeling interface, press the shortcut key Command/Ctrl+i to select other unselected models, then you can do other operations to these models in batches.
7.Add various New Text Fonts for the 3D Text function
When you choose to input 3D text, you will see a variety of new fonts that you could apply to the 3D text models.
8.Add Custom Flip function
The Custom Flip function allows you to define a flip plane by three points, and the model will be mirror flipped against this reference plane.
1) Select the shape, hover the "Flip" option and click "Custom Flip"
2) Then define a flipping reference plane on the model with three points. Then a new flipped model will appear next to the original model.
9.Support selecting the starting point to copy the model
When using the model copy function before, the starting point is the default of the system. And in this update, after you select the model to copy, you can select the starting point to copy and move (copy and paste shortcut keys: Ctrl/Command+C and Ctrl/Command+V).
0 6399 2
评论(2)
Oscar Hernandez 2022-7-27
fdd
Alza Arquitectos 2022-4-21
Great functions!
