Customize Ceiling, Wall, Floor supports the use of material brushes,and more
Homestyler Official 28 Marzo 2022
1.Customize Ceiling, Wall and Floor now supports the use of material brush
You can now use the material brush tool in the Customize Ceiling, Wall and Floor interface!image.png
2.Customize Ceiling and Floor function has expanded the extrusion size range to more than 2000mm
After you draw a shape in the Customize Ceiling or Customize Floor environment, you could type in the thickness value in the Extrusion input box, and now the range of extrusion has been expanded to more than 2000mm (not applicable for the "Customize Wall" function).image.png
0 3643 0
