How to render an aerial view or top view image?
To render an aerial image, simply switch to "Aerial" from the top. After setting up the "Resolution", "Aspect Ratio", and "Lighting" of the image you need to render, with the camera view adjusted by directly dragging in the central window and the upper right viewport, just click "Render" below to submit the rendering. After which, click on "Images" from the upper right corner and you can find the rendering progress and the final renders in the album.
0 1324 1
Commenti(1)
Noura Mohammed 27 Settembre 2022
and how to render top view of basement floor ? whenever I press render even if I'm choosing to hide the other floors but I still when I press render top vies it shows the floors above it .. how to deal with this ??
