How to set the starting point of tile flooring?
Homestyler Official 2022-1-17
Click "Customize-Tile Flooring" and select the wall or floor to enter the tile flooring interface. After you pave the surface, select the tiled surface, click "Start Point" to set the starting point of the tiling. You can also change the starting point of the tile in the right property panel under "Precise Paving-Start Point".
0 983 0
