Upgraded the brand new User Interface
Homestyler Official 2021-3-17
Floor Planner 08/2021 Release Notes - 【General Features】 related updates
1.Upgraded the brand new User Interface
The era of homestyle4.0 has begun! The concise visual interface, flexible and faster operating experience, and brand-new efficient functions - all these will improve your design efficiency.
Detailed tutorial:
2.New entry for Preferences & Measurement Unit setting
3.Updated the "Beginner's Guide"
4.Added side menu bar to enable faster model searching
5.Added transparent wireframe mode setting
6.Supported function panel customization
7.Optimized category structure in the replacement panel
8.Updated Interactive Fabric to simulate fabric effect
Take curtains as an example:
Detailed operation:Open the "Interactive Fabrics", place the "Curtain" model near the window, and click the "Wind Blow" button to set the wind force. Eventually, curtains blown up by the wind are automatically generated.
9.Added elevation view in the design interface
10.Wall opening and niche increased arch height adjustment
11.Models added related category recommendation
12.The model information added Model ID
13.Models supported alignment in 9 ways
14.Model supported horizontal or vertical distribution
15.Model supported scaling by dragging
16.Model supported exact and fast copy with shortcut
17.Supported customized and separate display of hidden items
18.Supported applying current materials to the same models
19.Window sill width supported width setting
20.Models in "My Fav" can be deleted or moved in batches
21.Models in "My Fav" supported to be searched
22.The 3D view supported to use the"space bar" to rotate the view angle
0 2695 0
